» Online brugere: 839
0 medlemmer og 839 gæster
Gammel 28-01-2009, 20:24
Jo jo
Det er 2`den styrmanden og 3`die styrmanden man hører - her er et fragment fra rapporten der beskriver den detalie
The first Mayday call was received from the ESTONIA at about 0122 hrs, i.e. at about the same time as the lifeboat alarm was given and just after the main engines had stopped. It was a very brief message, containing no other information than the word “Mayday” and the name ESTONIA. The operator has been identified by voice as second officer A on duty. In later radio traffic the operator has been identified as the third officer. A voice heard in the background has been identified as the chief officer's. He and the third officer had come to the bridge obviously alarmed.
The time for the distress traffic, from the first call to the last, was eight minutes. Nothing is mentioned to indicate that the officers had any appreciation of what had caused the vessel to develop a list and take in water. The information given was1: “Yes, we have a problem here now, a bad list to starboard. I believe that it was twenty, thirty degrees” followed later on by “We have black out” and, at the end of the distress traffic, “Really bad, it looks really bad here now”. It was about seven minutes before the Estonia gave her position. Due to the very fast development of the accident the late start of the distress traffic did not, however, have much effect on the final outcome of the rescue operation. The distress traffic is reproduced in full in 7.3.3. Figure 13.5 illustrates the development of the list during the distress traffic as experienced on the bridge.
Figure 13.5 Development of the list as observed on the bridge.
Of the five officers known to have been on the bridge, second officer A and the third officer were seen leaving the bridge in the final stage of the accident. It is believed that the master, the chief officer and the fourth officer remained on the bridge throughout the accident. This assumption is also supported by the fact that three bodies were seen inside the bridge during the diving investigation.
The two officers that left the bridge were later seen distributing lifejackets and trying to launch lifeboats and rafts. Also the boatswain, who just before the start of the accident was called out to help investigate the sounds on the car deck, was seen on deck 7 taking part in this.
It is noteworthy that so little exchange of information seems to have taken place between the bridge and the engine control room during the development of the accident. The third engineer did not inform the bridge about the inflow of water he observed (see 6.2.3). Nor did the officers of the watch call him for an assessment of the situation. If the observation on the monitor had been discussed and evaluated immediately, there could still have been a possibility to influence the development of the accident.
Nothing indicates that the officers realised that the bow was fully open, although it must have been obvious that the situation was very serious, and that the survival of the vessel was threatened.
Medlemmer: 134,225
Velkommen til vores nyeste medlem, DanChaise
Alle tider er GMT +1. Klokken er nu 04:20.
