» Online brugere: 4,806 |
| 0 medlemmer og 4,806 gæster |
12-05-2009, 15:33
Bopæl: nær odense
Northstar M121 ,2Khz rader, kort ,transduser
Low Profile, høj funktionalitet ... Explorer M121
DISPLAY DISPLAY
Display Size Display Størrelse 12.1 in \ 307 mm 12.1 i \ 307 mm
Display Resolution Display resolution 800 X 600 (H x W) 800 X 600 (H x W)
Display Type Skærmtype LCD LCD
Graphical Analog Displays Grafisk Analog Displays Yes Ja
Graphical Numeric Display Grafisk Numeric Display Yes Ja
Backlighting Color Baggrundsbelysning Color White Hvid
Backlighting Levels Baggrundsbelysning Niveauer 16 16
Display Modes Display Modes 12 User Selectable, 5 Programmable Favorites (H x W) 12 Bruger Valgbar, 5 Programmerbar favoritter (H x W)
Resize Display Window Resize Display Window Yes Ja
Sonar And GPS Overlay Data Sonar og GPS Overlay Data Yes Ja
Sonar Overlay Data Sonar Overlay Data Yes Ja
Split Screen Presentation Split Screen Præsentation Yes Ja
Multilanguage Display Multilanguage Display Yes Ja
Languages Supported Sprog, der understøttes 13 13
SONAR / SOUNDER SONAR / sundere
Sonar Frequency Sonar Hyppighed 50 kHz and 200 kHz kHz 50 kHz og 200 kHz kHz
Transducer Type Transducer Type Various: See transducer selection table Various: Se transducerne udvælgelse tabellen
Sonar Output Power Sonar Udgangseffekt Max 600w or 1000W depending on transducer used. Maks. 600 W eller 1000W afhængigt transducerne anvendes. W W
Sonar Depth Sonar Dybde Max 3300 ft \ 1000 m Max 3300 ft \ 1000 m
Standard Fishfinder Features: COLORLINE™/GRAYLINE®, ASP™, FishSymbol ID™, FishTrack™, and more Standard Fishfinder Features: COLORLINE ™ / GRAYLINE ®, ASP ™, FishSymbol ID ™, FishTrack ™, og mere Yes Ja
Sonar Alarms: Fish, Max and Min Depth Sonar Alarmer: Fisk, Max og Min Dybde Yes Ja
Depth Alarm Dybde Alarm Yes Ja
Temperature Display Temperatur Display Yes Ja
Depth Trend Dybde Trend Yes Ja
Depth Units Dybde Enheder Yes Ja
Fish Detection Fisk Detection Yes Ja
Sounder On/Off Sundere On / Off Yes Ja
GPS / NAVIGATION GPS / NAVIGATION
GPS Antenna Type GPS Antenne Type Northstar Model 124 GPS Antenna Northstar Model 124 GPS Antenne
GPS Receiver Channels GPS Receiver Kanaler 12 channels 12 kanaler
Background Map Baggrund Map 32 MB 32 MB
Waypoint Storage Vejpunkt Storage 3000 3000
Graphic Marker Icons Graphic bogmærkeværktøj Ikoner 48 48
Man Overboard Feature Mand over bord Feature Yes Ja
GPS Alarms GPS-alarmer Yes Ja
GPS Interface GPS Interface Yes Ja
GPS Position Accuracy GPS-position Nøjagtighed 33 ft \ 10 m 33 ft \ 10 m
GPS Update Rate GPS Update Rate 1 1
Waypoint Identity Vejpunkt Identity 48 48
AUTOPILOT / AUTOSTEERING AutoPilot / AUTOSTEERING
Automatic and Manual Seastate Control Automatisk og manuel Seastate Control Yes Ja
Automatic Tuning Automatic Tuning Yes Ja
Mounting Selectable Port Or Starboard Mounting Valgbare havn eller Starboard Yes Ja
RADAR RADAR
Antenna Type Antenna Type 12 Channel GPS-WAAS EGNOS Enabled 12 Channel GPS-WAAS EGNOS Enabled
Radar Chart Overlay Radar Chart Overlay Yes Ja
NETWORKING / CONNECTORS NETVÆRKSSAMARBEJDE / Konnektorer
NMEA 0183 Input NMEA 0183 Input Yes Ja
NMEA 0183 Interface NMEA 0183 Interface BWR, DPT, GGA, GLL, GSA, GSV, HDG, HDM, HDT, MTW, MWV, RMC, VHW, VTG and DBT BWR, DPT, GGA, GLL, GSA, GSV, HDG, HDM, HDT, MTW, MWV, RMC, VHW, VTG og DBT
NMEA Output NMEA Output APA, APB, BWR, DBT, DPT, GGA, GLL, GSA, GSV, RMB, RMC, MTW, VHW, VLW, VTG, XTE APA, APB, BWR, DBT, DPT, GGA, GLL, GSA, GSV, RMB, RMC, MTW, VHW, VLW, VTG, XTE
TECHNICAL / ENVIRONMENTAL TEKNISKE / MILJØSPECIFIKATIONER
Built-in Backup Memory Indbygget i Backup Memory Yes Ja
Mounting Mounting Flush mount, Bracket Mount (Bracket Included) Flush mount, Bracket Mount (Bracket Included)
Waterproof Standard Vandtæt Standard IPX7 IPX7
Width Bredde 15.1 in \ 383.5 mm 15.1 i \ 383,5 mm
Height Højde 10.1 in \ 256.5 mm 10.1 i \ 256,5 mm
Depth Dybde 3 in \ 76.2 mm 3 i \ 76,2 mm
POWER POWER
Power Supply Power Supply 10.5 to 32 V DC vDC 10,5 til 32 V DC VDC
Power Consumption Effektforbrug at 13.8 V 350 mA min - no backlighting. på 13,8 V 350 mA min - ingen baggrundsbelysning. 1A max - full backlighting 1A max - fuld baggrundsbelysning
Power Consumption Lights Off Effektforbrug Lights Off 350 mA 350 mA
Power Consumption Lights On Effektforbrug Lights On 1000 mA 1000 mA
OTHER ANDRE
Adjustable Gain Justerbar Gain Yes Ja
Alarm Output Alarm Output Yes Ja
Auto Seastate Auto Seastate Yes Ja
Average Speed Average Speed Yes Ja
Bearing To Waypoint Bearing Til vejpunkt Yes Ja
Chart System Chart System C-Map Max C-Map Max
Course Over Ground Course Over Ground Yes Ja
Course Up Presentation Kursets Up Præsentation Yes Ja
Cross Track Error Cross Track Fejl Yes Ja
Cursor Control Markør Control Yes Ja
Data Card Data Card Yes Ja
Distance To Waypoint Afstand til waypoint Yes Ja
Dual Chart Dual Chart Yes Ja
Electronic Bearing Line Elektronisk pejlelinje Yes Ja
Environmental Rating Environmental Rating IPX7 IPX7
External Alarm Eksterne Alarm Yes Ja
Lat/Long Display Lat / Long Display Yes Ja
Log Units Log Enheder Yes Ja
Manual Automatic Control Manuelt Automatic Control Yes Ja
Memory Card Capable Memory Card Capable Yes; Waypoints, Routes, Tracks to C-Map Memory Card Ja; Waypoints, ruter, spor til C-Map Memory Card
Message Indicator Message Indikator Yes Ja
Night Illumination Night Belysningskommission Yes Ja
Non Volatile Memory Ikke Flygtige Memory Yes Ja
North Up Presentation North Up Præsentation Yes Ja
Operating Temperature Driftstemperatur 0° to 50°C 0 ° til 50 ° C
Port Information Port Information Yes Ja
Sea Temperature Hav Temperatur Yes Ja
Speed Damping Speed Damping Yes Ja
Speed Display Speed Display Yes Ja
Speed Over Ground Speed Over Ground Yes Ja
Speed Trend Speed Trend Yes Ja
Speed Units Speed Enheder Yes Ja
Supplied With Leveres med GPS Antenna, Sounder, Bracket, Power Cable, Manuals GPS-antenne, Sundere, Bracket, strømkabel, Manualer
Syncronized Radar And Chart Syncronized radar og figur Yes Ja
Tide Tables Tide Tabeller Yes Ja
Time To Go To Waypoint Time To Go Til vejpunkt Yes Ja
Trip Log Trip Log Yes Ja
True And Relative Motion True og relativ bevaegelse Yes Ja
Type Of Equipment Maskintype Multifunction, Non-Networked Multifunktion, Ikke Networked
Variable Range Marker Variable afstandsringe Yes Ja
DER ER DET STORER KORT ekkolod transduser
2 Khz Rader
så skulle du vist ikke mangle nået ......
kan monter det mod meer pris..........
12-05-2009, 15:35
Bopæl: nær odense
Har billeder .......
men ved sku ik lige hvordan man sætter dem ind her .... nogen der li kan hjælpe mig
12-05-2009, 15:54
Brug funktionen "vedhæftede filer" hvis du uploader fra din pc
Kan du ikke klare det så mail mig billederne på mail så skal jeg indsætte dem
Sidst redigeret af ENN; 13-05-2009 kl. 08:34.
12-05-2009, 16:22
Bopæl: nær odense
12-05-2009, 16:50
Gør hvad - mailer dine billeder eller vedhæfter dem???
Mailer dem gør du via dit mailprogram og vedhæfter dem gør du via funktionen "håndter vedhæftelser" som er under dialogboksen når du laver et indlæg
12-05-2009, 16:57
Men hvad går dette indlæg egentlig ud på ?? Hvis du vil køre det som en auktion bør du da angive en startpris/mindstepris eller lignende, samt en løbetid på auktionen.
12-05-2009, 21:09
Bopæl: nær odense
Auktion
Start pris 20.000.- kr løbe tid 7 dag fra d.d
12-05-2009, 21:10
Bopæl: nær odense
Een
13-05-2009, 08:34
Ja vedhæfte billeder
13-05-2009, 13:13
Bopæl: nær odense
Een
det kan jeg sku ik finde udaf ..........
Sidst redigeret af 2farst4you; 17-08-2009 kl. 13:51.
13-05-2009, 13:14
Bopæl: nær odense
Juhuuuuuuu
nååå sådan......kunne i da bare have sagt
13-05-2009, 13:15
He he yes så virker det
Fint anlæg du sælger der - med mange features - ser ud til at være et super tilbud
13-05-2009, 14:16
Bopæl: nær odense
Een
jaa der er sku nogen der tjener en del når de sælger sådan nået.........
HELLER TJENE LIDT... MANGE GANGE..
END MEGET... FÅ GANGE !!!
17-05-2009, 10:56
Bopæl: nær odense
Hmmm
igen der skulle til lommene......
17-05-2009, 10:57
Bopæl: nær odense
KOMMMMM nu
det er guf for kenner.......
| Emne |
Emne forfatter |
Forum |
Svar |
Sidste indlæg |
kort
Casper T |
Elektronik |
4 |
14-07-2009 14:39 |
