» Online brugere: 697
0 medlemmer og 697 gæster
Gammel 28-01-2009, 20:24
Jo jo
Det er 2`den styrmanden og 3`die styrmanden man hører - her er et fragment fra rapporten der beskriver den detalie
The first Mayday call was received from the ESTONIA at about 0122 hrs, i.e. at about the same time as the lifeboat alarm was given and just after the main engines had stopped. It was a very brief message, containing no other information than the word “Mayday” and the name ESTONIA. The operator has been identified by voice as second officer A on duty. In later radio traffic the operator has been identified as the third officer. A voice heard in the background has been identified as the chief officer's. He and the third officer had come to the bridge obviously alarmed.
The time for the distress traffic, from the first call to the last, was eight minutes. Nothing is mentioned to indicate that the officers had any appreciation of what had caused the vessel to develop a list and take in water. The information given was1: “Yes, we have a problem here now, a bad list to starboard. I believe that it was twenty, thirty degrees” followed later on by “We have black out” and, at the end of the distress traffic, “Really bad, it looks really bad here now”. It was about seven minutes before the Estonia gave her position. Due to the very fast development of the accident the late start of the distress traffic did not, however, have much effect on the final outcome of the rescue operation. The distress traffic is reproduced in full in 7.3.3. Figure 13.5 illustrates the development of the list during the distress traffic as experienced on the bridge.
Figure 13.5 Development of the list as observed on the bridge.
Of the five officers known to have been on the bridge, second officer A and the third officer were seen leaving the bridge in the final stage of the accident. It is believed that the master, the chief officer and the fourth officer remained on the bridge throughout the accident. This assumption is also supported by the fact that three bodies were seen inside the bridge during the diving investigation.
The two officers that left the bridge were later seen distributing lifejackets and trying to launch lifeboats and rafts. Also the boatswain, who just before the start of the accident was called out to help investigate the sounds on the car deck, was seen on deck 7 taking part in this.
It is noteworthy that so little exchange of information seems to have taken place between the bridge and the engine control room during the development of the accident. The third engineer did not inform the bridge about the inflow of water he observed (see 6.2.3). Nor did the officers of the watch call him for an assessment of the situation. If the observation on the monitor had been discussed and evaluated immediately, there could still have been a possibility to influence the development of the accident.
Nothing indicates that the officers realised that the bow was fully open, although it must have been obvious that the situation was very serious, and that the survival of the vessel was threatened.
Gammel 28-01-2009, 20:35
Jo Jo..... han har sgu gode øre.. men er knapt så god til at finde rundt i en havarirapport..........
Det er stadigt spændende
Gammel 28-01-2009, 21:07
I overmorgen er det som sagt 50 år siden Hans Hedtoft gik ned - har du læst denne bog Stroyer
Den er aldeles framragende og fortæller også om telegrafistlivet på Grøndland og Grønlandsfarten.
Den er udsolgt fra forlaget - men kan måske lånes på biblioteket - det er en bog du vil nyde
Skulle det være håbløst at finde den har jeg et eksemplar - den ligger i soveværelset i Sverige - men jeg tager den gerne med hjem hvis du vil læse den
Der findes 2 bogudgivelser om Hans Hedtoft - den viste og en mindre jeg også har - udgivet af en Jan Schmidt (jeg tror faktisk at jeg har 2 eksemplarer af den) der skulle også komme en film om Hans Hedtoft se bare her: http://janss.dk/blog/film-om-groenla...s-hedtofts.php
Gammel 28-01-2009, 21:16
Den ene bog -er den afbildede - den anden af Jan Schmidt er en mindre bog begge er udgået fra forlaget men den lille bog kan faktisk læses kvit og frit på denne side:
http://janss.dk/hedtoft.php
Der findes 2 "originaler" (ment meget positivt) der studerer Hans Hedtoft forliser - Jan Schmidt som har skrevet den lille bog og en navigatør ved navn Enoch som i mange år har forsøgt at finde positionen hvor den sank - de skriver begge på denne side http://janss.dk/blog/film-om-groenla...s-hedtofts.php
Sidst redigeret af ENN; 30-01-2009 kl. 10:07.
Gammel 28-01-2009, 21:38
Han henviser selv til den ene af bøgerne, Det er spændene læsning.
Da det stod klart, at "Hans Hedtoft" var gået ned med alle mand, blev der stor opstandelse i pressen. Alle huskede to år tilbage, da der var meget skriveri om "Umanak"s hårde tur til Grønland.
dette udsnit er særligt interessant for mig, For da min far startede som gnist var det i prins chr. sund og derefter på pointen i narssaq. i narssaq boede vi ved siden af et par hvor konen havde været med på "Umanak" og to år senere sidder i prins chr. sund da Hans Hedtoft sank.
Hende (Jelva) har vi stadig kontakt med hun bor i Aalborg.
Gammel 28-01-2009, 21:46
Der er også en anden version af "TERNEN"s forlis ?????
"Ternen" søgte læ, for det hårde vejr, ved Ravn Storø. Hovedankeret havde besætningen tidligere lagt i land. Reserveankeret kunne ikke holde skibet, så de sejlede lidt rundt, medens de ventede på bedre vejr. Under rundsejladsen kom "Ternen"s bagbord side op på et skær, derved krængede skibet kraftigt til styrbord. En luge på fordækket i styrbord side stod åben. Vandet løb ind, og skibet sank. Forliset skete meget hurtigt. Et af besætningsmedlemmerne blev bogstavelig talt taget med bukserne nede. Der var ialt otte marinesoldater ombord på Ternen. Alle otte omkom ved ulykken, men kun de fem blev efterfølgende fundet.
Senere gik en dykker ned og lukkede lugen, skibet blev pumpet tom for vand, og dukkede op til overfladen. "Ternen" kunne fortsætte sin gerning som inspektionsskib.
Gammel 28-01-2009, 22:01
Nu bliver det sgu uhyggeligt,
For Jelva var med på opturen med "Umanak" og var ved kap farvel på samme tidspunkt som min farbror druknede da "Ternen" gik ned.
Og de var med i eftersøgningen efter "Ternen".
min farbror s lig var ombord på "umanak" på hjemturen hvor en matros blev slået ihjel.
Jelva sad på radiostationen på pointen 4 km udenfor Narssaq da mine forældre flyttede dertil 3-5 år senere.
Min far skulle arbejde i vagt med Jelva..........
Gammel 29-01-2009, 07:56
Rettelse:
Jelva sad ikke på Prins chr. Sund under "Hans hedtoft"s forlis, Da det var en station kun for Mænd.
Hun Sad på radiostationen i Narssaq.
Gammel 29-01-2009, 17:40
Hvis du låner den store bog om Hans Hedtoft så vil du sikkert kunne få flere brikker til at falde på plads - der er masser af information om radiostationerne på grønland etc etc
Det slående i tråden er at det selv for professionelle åbenbart er svært at føre en korrekt VHF komunikation - og at vi vist alle kunne have glæde af et kursus så vi lærer hvordan man betjener en VHF korrekt
Gammel 29-01-2009, 20:33
Jeg kan ikke være mere enig..
Jeg var desværre forhindret da vi havde VHF DSC. kursus på LP-Yacht :-(
Gammel 23-02-2009, 18:13
I forbindelse med 50-årsdagen for forliset udgives bogen:
"Skibet der forsvandt - Historien om Hans Hedtofts gådefulde forlis"
Forfatterne Lars Halskov og Morten Halskov, har fået adgang til tidligere hemmeligholdte dokumenter, private breve, lommebøger, dagbøger samt en række intern papirer.
Den er jeg også lige blevet skrevet op til,
Ligesom jeg er skrevet op til Jan Schmidt`s bog.
Gammel 23-02-2009, 18:58
Så mangler du kun "i de bedste hænder" som er måske den mest omfattende bog om Hans Hedtoft`s forlis - det med de "tidligere hemmeligholdte dokumenter" er en gang snak - der er ingen hemmelige dokumenter mig bekendt - men det fænger godt når man skal udgive endnu en bog om et emne
Gammel 23-02-2009, 19:00
Den er jeg også skrevet op til.
Gammel 05-03-2009, 20:04
Så er den læst..
har fundet ud af at skipperen på umanak`s færd også har været skipper på "M/S Tikerak" der brændte i 1966 og sank imellem Egedsminde by og "Tørveøen"
Min far som også var dykker på Grønland har bjerget bla. tågehornet og en blok fra "Tikerak"
Vi kunne se hvor den lå fra stuevinduet
Gammel 23-02-2009, 19:30
Jans Jans er offline
Bopæl: Vesthimmerland
Strøyer
Jeg ser lige, at du er skrevet op til min bog. Jeg tror nu ikke du skal have for store forventninger om at få den. Gennem tiden har jeg fået utrolig mange forespøgsler på den. Man skal også være heldig for at skaffe den antikvarisk.
Egentlig var det min mening, at den skulle have været genoptrykt sammen med nogle andre beskrivelser. en pga. indtrufne omstændigheder tvivler jeg meget stærkt på at det bliver til noget.
Det skal også nævnes, at den version der er online er bedre. Der er nogle opdatering, og en kronik om forliset, skrevet af redaktør Palle Brandt, som er langt senere end bogen.
Jeg har en formodning om, om at den snart findes som ebog. Når det er tilfældet vil det fremgå af min side.
Så vidt jeg husker havde du stor interesse i Ternens forlis. Hvis du ikke kender denne side, så prøv at kigge. Der er en hel del billedder fra bjærgningen.
http://www.navalhistory.dk/danish/bi...nen/ternen.htm
Venlig hilsen Jan
Min hjemmeside handler om Søfartshishistorie og Ulykker til søs.
Gammel 23-02-2009, 19:39
Originally Posted by Jans Se indlæg
Strøyer
Jo den side kender jeg udemærket, Jeg har selv sendt oplysningerne om Bendt Ferdinand Sørensen, Og et foto af ham,
Til Balsved, Tror jeg han hed
Det er på biblioteket jeg er skrevet op til din bog, De sagde at de havde den.
Ellers må jeg jo ty til E-bogen, Men det er jo ikke helt detsamme som at ligge på sofaen med en god bog.
Gammel 29-01-2009, 21:35
Ja så er det sådan i disse timer ret præcist 50 år siden at Hans Hedtoft gik ned ved Kap farvel
Gir man ind her: http://www.dr.dk/kroniken/1950erne/i...forliset_1.asp
Så er der sørme en film med Hans Hedtoft fra en prøvetur på Øresund
Gammel 29-01-2009, 21:48
Der kommer lige et lys i vinduet..
Gammel 29-01-2009, 22:11
Hans Hedtoft var bygget som et polarskib men desværre var den bygget som et "1 rums" skib det betød det kunne flyde med 1 vandtæt sektion vandfyldt
Radiokomunikationen tyder på at det fin hul i BB side i såvel hoved maskinrum som hjælpemaskinrum formentligt forårsaget af en kollision med storis eller et isbjerg og så var det dødsdømt idet det ikke kunne holde sig flydende med 2 sektioner vandfyldt
Hans Hedtoft havde dobbelt bund men kun enkelt sider - i bunden lå en masse tanke så blev der slået hul ville kun tanken blive vandfyldt skibet ville så flyde på tanktoppen - siderne havde ikke denne konstruktion
Argus som blev bygget 12 år senere og minder en del om det var bygget med dobbelte sider - altså det man kalder højtanke omkring maskinrum etc og havde Hans Hedtoft haft denne konstruktion er det sansynligt at den havde klaret sig.
Hans Hedtoft blev desværre bygget med et begrænset budget og blev derfor teknisk set ikke så sikkert som man kunne ønske - selvom det bestemt ikke var et dårligt polarskib
Argus som ses her (på billedet som Esvagt Alpha - det er i dag ejet af Esvagt):
Er bygget ca 12 år senere men har mange ligheder med Hans Hedtoft dog er det nærmest bygget uden hensyntagen til noget budget og man ville opnå det absolut sikreste polarskib der kunne bygges - det sejlede på Grønland i mange år i ekstreme vejr og isforhold - men overlevede alle uheld etc. Det er bygget teknisk noget anderledes end Hans Hedtoft bla har det som nævnt dobbelte sider omkring hoved og hjælpemaskinrum og desuden har det 2 hovedmaskiner etc etc. Jeg har været ombord på det en del gange tidligere og det er et ekstremt skib at være på
De vandtætte skotter går helt op til øverste dæk (under skorstenen) og man går gennem vandtætte døre hele tiden - det kan lukkes af i så mange vandtætte sektioner at det er svært at forestille sig at det kan gå ned selv efter et møde med et isbjerg
Sådan et skib bliver der nok ikke bygget igen da det kostede en formue at bygge - alt var gjort for at sikre at en ny katastrofe ala Hans Hedtoft ikke skulle ske - og det gjorde den så heller ikke - i hvert fald ikke med argus
Gammel 29-01-2009, 22:21
Hans hedtoft var også svejset sammen i sider og bund, og det var før man helt havde styr på de spændinger der kom af svejsning Men spanderne var nittet.
Det er endnu ikke klart om den ramte et isbjerg eller at den sejlede over et af de skær som der har været rapporter om i det område de var på 9m. vand men i en storm vil der i en bølgedal være væsentligt mindre vand over skæret.
en terori er at den ramte sådan et skær og slog hul i skroget udfor det vandtætte skot så der kunne trænge vand ind i begge kamre, Eller at skottet blev beskadiet så døren ikke kunne lukkes.
Medlemmer: 134,225
Velkommen til vores nyeste medlem, DanChaise
Alle tider er GMT +1. Klokken er nu 02:52.
