» Online brugere: 604
0 medlemmer og 604 gæster
Gammel 27-06-2008, 20:04
Mercruiser værkstedsmanualer
Her er et link til en mængde af Mercruisers værkstedsmanualer
Service Manual #1 1963- 1973 All Engines and drives
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/01/cover.pdf
Service Manual #2 1974 to 1977 All Engines and drives.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/02/cover.pdf
Service Manual #3 1978 - 1984 All engines
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/03/cover.pdf
Service Manual #4 1978 to 1982 120 to 260 Sterndrives (aka One drives)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/04/cover.pdf
Service Manual #5 1978 to 1993 TR - TRS outdrives
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/05/cover.pdf
Service Manual #6 R, MR, Alpha I outdrives 1983 to 1990
Must open each section individually to save.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/6/6covr3.pdf
Service Manual #7 GM V6 1983 - 1993
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/7/7cov.pdf
Service Manual #8 1985 to 1989 Merc Marine 4 cyl (Newer 470's)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/08/cover.pdf
Service Manual #9 1985-1988 GM V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/09/cover.pdf
Service Manual #10 1985- 1989 GM 4 cylinder (120-140)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/10/cover.pdf
Service Manual #11 Bravo Outdrives 1988 to 1998
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/11/11covr5x.pdf
Service Manual #13 GM 4 cylinder engines. 1990 to 1997
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/13/13covr2.pdf
Service Manual #14 Alpha I Gen II Outdrives 1991 to present
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/14/14cover.pdf
Service Manual #15 1989-1992 GM V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/15/cover.pdf
Service Manual #17 GM V8 305 and 350 cid (5.0L 93-95) 1993 - 1997
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/17/17cov2r2.pdf
Service Manual #18 GM V6 Gen II with Balance Shaft 1993 - 1997
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/18/18covr2.pdf
Service Manual #23 GM Big Block 1998 - 2001
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/23/23covr1.pdf
Service Manual #24 GM Small Block V8 1998- 2001
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/24/24covr1.pdf
Service Manual #24 Supplement GM 6,2L 98-01
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/24sup/24suppco.pdf
Service Manual #25 GM V6 1998 - 2001
Opens 1st 3 sections. You need to open, download, and save other sections.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/25/25covr1.pdf
Service Manual #26 GM 4 Cyl 1998 -
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/26/26covr1.pdf
Service Manual #28 2001- newer Bravo drives. ALL
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/28/28cover.pdf
Service Manual #30 2001 - newer 8.1L
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/30/30cover.pdf
Service Manual #31 2001 - newer GM Small Block V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/31/31cover.pdf
Service Manual #32 2001 - newer GM V6 MPI Sections only must open and save each section.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/32/32cover.pdf
Service Manual #33 555 Diagnostics Big Block
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/33/33cover.pdf
Service Manual #36 555 Diagnostic Small Block V6 and V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/36/cover36.pdf
Gammel 28-08-2008, 18:42
Mr. Glastron Mr. Glastron er offline
Hej Alle.
Synes ikke rigtig jeg ka åbne ovenstående link.. Er der andre der har bedre held med det,
eller er linket bare dødt.?
Ps. Kanon forum, både nytdrev.dk forum og Fenderen.dk som har lært mig meget.:-)
Mvh Martin
Gammel 28-08-2008, 18:45
Velkommen til
Linket virker fint hos mig - du klikker på linket og klikker på om det er service builetiner workshopmanual (værkstedsmanual) etc så åbnes et nyt vindue - så klikker du på det kapittel du vil åbne og så åbner det
Gammel 28-08-2008, 19:01
...Mærkeligt, hos mig siger den "There was an error opening this document. The file cannot be found"
Mvh Martin
Gammel 28-08-2008, 19:02
Underligt - har du acrobat reader instaleret - det er nemlig det format det ligger i
Gammel 28-08-2008, 19:15
Ja det har jeg.. Ka godt åbne forsiden, men ikk de efterfølgende. Hvilken version har du?
Gammel 28-08-2008, 19:16
Hmmm virker også fint her..
MR. Glastron - hvilken manual er det du skal bruge? "psst" det kan nemlig være jeg har en liggende du kunne "downlåne"
Gammel 28-08-2008, 19:23
he he det kunne være rigtig dejligt. Ska bruge en manual til min mercruiser inline 6 165hp.
Mvh Martin
Gammel 28-08-2008, 19:26
Ka man være så heldig at Manualen til mit alpha 1 gen one osse kan finde på samme måde:-)
(det drev med øjet i toppen, og køleripper på siden.)
Mvh Martin
Gammel 28-08-2008, 19:28
Det lyder som et alpha 1 det du har her er en oversigt over alle mercruiser drev - find dit via teksten og billederne
Mercruiser 1 1966 - 1983
A = Løfteøje
B = Ribber
C = 11 mm hul
A = fjederstift
B= rund kaviations plade
Dette drev KAN erstattes med et Mercruiser Alpha One drev - også det nedre drev kan erstattes med et Alpha one drev det kan IKKE erstattes hverken helt eller delvist med et Alpha One Generation Two!!
1984-1990 R, MR, Alpha One
A = flat dæksel
B = Glat overflade
C = 12,5 mm åbning
A = "A" indstemplet
B = kantet kaviatations plade
C = Ingen fjederstift undtagen model "R"
1991 - Alpha One Generation Two
Over og underdel er samlet med gennemgående bolte/møtrik
Dette drev kan IKKE erstattes hverken helt eller delvist af pre Alpha 1 gen 2 drev, men det nedre gearhus er ens på alle udvekslingsmodeller - det øvre er der hvor udvekslingen afgøres - højre/venstreløbs modeller findes - det er det nedre gearhus der afgør om det er en h eller v løbende model.
Der findes andre Mercruiser drev end de ovenfor nævnte - men de er mere sjældne - skulle du ikke genkende dit drev i ovenstående guide så kan du prøve at kigge her:
Mercruiser TRS 1970-1990
Mercruiser TR 1970-1990
Mercruiser Super Speed Master (ClubFoot)
Mercruiser Bravo 1 1991-
Mercruiser Bravo 2 1991-
Mercruiser Bravo 3 1991-
Mercruiser Black Hawk 1991-
Vil du have mere information end ovenstående kan du besøge denne side
http://www.mercstuff.com/drive_id.htm
Gammel 28-08-2008, 19:33
Sorry Glastron-man - de ældre årgange kan jeg desværre ikke være behjælpelig i
Gammel 28-08-2008, 19:34
Som jeg ser det er mit drev et "pre" alpha drev, men det magen til drevet på de øverste 2 billeder.
Ka det passe?
Gammel 28-08-2008, 19:36
Her på Fenderen kan vi da hjælpe med alt
her er manualen du søger:
http://www-alt.mercurymarine.com/mne...l/6/6covr3.pdf
Det var ærgeligt. Sådan en manual er jo u-undværlig til sådan en gammel dame:-)
Der skulle vel ikke være andre der kan hjælpe
Mvh Martin
Gammel 28-08-2008, 19:37
det var da utroligt.. Ka heller ikk åbne den side
Gammel 28-08-2008, 19:38
Hallo - du har fået et link med manualen - kig her:
Jeg tror vi postede samtidigt
Gammel 28-08-2008, 19:40
Det må være et "lokalt" problem altså med din PC for linket virker perfekt - kan du prøve og se om din PC er opdateret og om du har et program der kan læse .pdf filer - eller kan du downloade en gratis acrobat reader her:
http://www.adobe.com/dk/products/acrobat/readstep2.html
Gammel 28-08-2008, 19:58
S[ virker det sku. M[tte en geninstallering til.
Gammel 28-08-2008, 20:00
Perfekt ;-)
Gammel 28-08-2008, 20:20
Jess's Avatar
Jess Jess er offline
Nogen der ved hvor man kan få fingre i en værkstedsmanual til en Tohatsu 115 TLDI ?
Nyt link med Mercruiser og mercury værkstedsmanualer ENN Vedligeholdelse/bundmaling/Reparation/Manualer 0 01-08-2009 14:54
Medlemmer: 133,475
Alle tider er GMT +1. Klokken er nu 21:45.
