» Online brugere: 373
0 medlemmer og 373 gæster
Gammel 29-04-2009, 17:53
Ethanol 15% blanding
Skal da passe på benzin med over 10% ethanol det kan blive en dyr fornøgelse
Farmers Lobby EPA
For 15% Ethanol
The chipped valve in the left pix was caused by a lean ethanol mix. The picture on the right shows where the resin that ethanol dissolved from a fuel tank ended up. The valve on the left won't seat properly and should look more like the valve on the right.
Not satisfied by the high food prices that 10% Ethanol gasoline has wrought, the farmers and ethanol-makers are now petitioning the EPA to approve 15% ethanol on the way to 25%. Not only will this raise the price of food stuffs in the U.S., it will ruin most marine engines. Not one engine manufacturer approves the use of their engines with gasoline with a mixture greater than 10% ethanol. There are 18 million boats currently in operation in the U.S., and none of them have been designed, certified or warrantied to run on anything above E10. Already, with just 10% ethanol, the engine makers are inundated with service and repair problems that have stretched their reduced staffs to the breaking point. Boaters across America have had to pay for new carburetors, seals, O-rings, valves and fuel tank replacements. Unless all boaters act swiftly and with passion, the well-financed ethanol lobby will steamroll the EPA into 15% ethanol. Last year boaters were able to defeat an onerous EPA measure in Congress, and this year we again call on you to register your thoughts again to defeat the 15% ethanol proposal. Sign up here (it will only take 30 seconds, and you will NOT be spammed) --
Gammel 30-04-2009, 18:21
Det er et indlæg lavet af en interessegruppe som jeg læser det
Erhanol findes allerede i benzin i de fleste lande - og vores GM/Vortec marinemotorer findes i industriversioner der kører på ren Ethanol
Man læsrer om mange "lommehistorier" om hvor galt det er med Ethanol iblanding - men i praksis giver det meget få/ingen problemer med iblanding af Ethanol - rent teknisk - men det giver lavere virkningsgrad og derved går noget af besparelsen tabt
Her i Sverige er der iblandet 10% ethanol til benzinen og det er der ingen problemer i - man undgår endda vand i brændstoffet idet ethanolen optager de fugtrester der måtte findes i brændstofsystemet og de brændes så af med brændstoffet
I Danmark har vi - som et af de eneste EU lande - endnu ikke mig bekendt ethanol i benzinen men det kommer meget snart
Man kan købe E85 på tankstatonerne her i Sverige (85% ethanol 15% benzin) og det kører en GM marinemotor fint på - man skal bare skifte dysser i karburatoren - og ydelsen falder ca 10% men derudover har de nyere GMèr ingen problemer med at æde det - dog stiger brændstofforbruget ca 15% og så er besparelsen gået fløjten
En litter E85 koster vist ca 9 Skr og en litter Benzin koster val ca 11 Skr
Gammel 30-04-2009, 20:22
Jeg skal ikke gøre mig klog på det, læste bare indlægget og lagde en kopi ind men hvis det er fakta kan det blive dyrt for mange af os med ældre motor.
Ethanol i benzin BrianL Generelle spørgsmål 7 23-10-2008 21:37
Medlemmer: 129,249
Velkommen til vores nyeste medlem, JulianaLid
Alle tider er GMT +1. Klokken er nu 00:33.
